I’ve been using Linux for about five months now, and I want to share my experience with Ubuntu for anyone coming from Windows. I tested around 10 different distros, including live CDs, and for a permanent installation, Ubuntu is the best choice for newcomers.
Why Ubuntu?
Ubuntu has a massive community and over 30,000 packages in its main repositories. Adding more is as simple as editing a few lines in /etc/apt/sources.list (or using the GUI in Software & Updates). Almost all software is free and open-source; commercial packages are rare and usually unnecessary for everyday use.
Installation & Dual Booting
If you have Windows 98, 2000, or XP installed, don’t worry—you can dual boot easily. Just free up around 5 GB (4.5 GB for / and 0.5 GB for swap). Use GParted to resize your Windows partition without losing data. The GRUB bootloader will detect all operating systems and let you choose at startup.
Accessing Windows Files
Mounting Windows partitions is straightforward. Edit /etc/fstab or use the GUI in your file manager. Once mounted, you can read and write to NTFS/FAT32 drives without issues.
Daily Use & Updates
Ubuntu receives updates daily (around 1–2 MB) to keep your system secure. The default browser is Firefox, which works great for web surfing. For office work, you have LibreOffice; for graphics, GIMP and Inkscape are ready. Everything is accessible via the command line or graphical menus, similar to Windows XP.
Hindi Language Support
अब हिंदी में: यह पोस्ट मैं उबंटू में ही लिख रहा हूं। हिंदी टाइप करना बहुत आसान है—बस Shift+Ctrl या Windows key दबाएं और भाषा बदल जाती है। उबंटू में हिंदी फॉन्ट और इनपुट मेथड पहले से मौजूद हैं। अगर आपको कोई समस्या हो, तो मैं मदद के लिए तैयार हूं।
Ubuntu isn’t perfect—some drivers (like modems) and proprietary plugins (Flash, RealPlayer) can be tricky. But the future is open-source, and moving to Linux is a step toward freedom. If you’re a new user, Ubuntu is the easiest gateway. I’m not an expert, but I’m happy to help anyone getting started.
