I ran into an issue where custom avatars would show an error message right below them. After digging around, I found that the problem usually comes from one of three things: a broken image path, a stale database entry, or a MySQL connection hiccup. Let me walk you through how I fixed it.
Check the Image Path
First, verify that the avatar image is actually where you think it is. If you’re using a relative path, make sure it’s correct from the script that renders the profile. On Xisto, your files are in public_html. I store avatars in public_html/avatars/ and link them like /avatars/username.png. Use file_exists() in PHP to double-check before displaying.
$avatar_path = '/avatars/' . $username . '.png';
if (file_exists($_SERVER['DOCUMENT_ROOT'] . $avatar_path)) {
echo '<img src="' . $avatar_path . '" alt="Avatar">';
} else {
echo '<img src="/default-avatar.png" alt="Default Avatar">';
Debug Database Lookups
If avatars are assigned via a user table column, the error might be because the query failed or returned NULL. Use prepared statements to fetch the avatar filename, and log any errors.
try {
$stmt = $pdo->prepare('SELECT avatar FROM users WHERE username = ?');
$stmt->execute([$username]);
$avatar = $stmt->fetchColumn();
} catch (PDOException $e) {
error_log('Avatar query failed: ' . $e->getMessage());
$avatar = false;
Then display a fallback if $avatar is empty.
MySQL Downtime
The error below the avatar could be a database connection error message if your code tries to fetch the avatar without handling a failed connection. On Xisto, you can check MySQL status in cPanel under “MySQL Databases” – sometimes it goes down for maintenance. A quick fix is to wrap your DB calls in a try-catch and show a static default avatar if the DB is unreachable.
try {
$pdo = new PDO('mysql:host=localhost;dbname=your_db', 'user', 'pass');
// fetch avatar
// DB down, show default
echo '<img src="/default-avatar.png" alt="Avatar">';
Final Tips
- Always use absolute paths from the web root (starting with
/) to avoid confusion. - Enable error reporting during development to catch warnings about missing files or failed queries.
- Cache avatars after fetching to reduce DB load.
If you’re still stuck, post your code snippet and the exact error text – that’ll help narrow it down.
