PHP-Nuke 7.5 Theme Installation Guide
:framed_picture:> Stock photo of a vintage computer monitor displaying a PHP-Nuke admin panel, with a modern laptop showing a CMS dashboard beside it, retro-futuristic style.
The Old Days: PHP-Nuke 7.5 Theme Setup
Ah, PHP-Nuke 7.5 – that brings back memories. For those who don’t know, PHP-Nuke was a popular content management system (CMS) back in the early 2000s, written in PHP. It used a simple theme system where themes were just folders with HTML, CSS, and images.
If you’re trying to install a theme on PHP-Nuke 7.5, here’s the step-by-step process:
  1. Upload the theme folder to themes/ directory on your server (via FTP or cPanel File Manager).
  2. Check the theme structure: It should contain a file like theme.php or index.html (depending on the theme type).
  3. Go to your PHP-Nuke admin panelThemes AdministrationSelect Theme – your new theme should appear in the dropdown list.
  4. If it doesn’t show up: Common issues include:
    • The theme folder missing a theme.php file (some old themes used index.html only).
    • Incorrect folder permissions (set to 755).
    • The theme is designed for a different PHP-Nuke version (e.g., 6.x vs 7.x).
Note: PHP-Nuke is long deprecated and highly insecure. Modern equivalents like WordPress, Joomla, or Laravel-based CMS are recommended for new projects. However, if you’re maintaining a legacy site, this guide still works.
Modern Comparison: How Themes Work Today
In 2026, CMS theme installation is much smoother:
  • WordPress: Upload a .zip file via admin panel → Activate.
  • Joomla: Install via Extensions Manager.
  • Custom PHP: Use Composer and template engines like Twig.
Code Example: Modern Theme Structure (Laravel Blade)
// resources/views/layouts/app.blade.php
<!DOCTYPE html>
<html>
<head>
    <title>@yield('title')</title>
    <link rel="stylesheet" href="{{ asset('css/app.css') }}">
</head>
<body>
    <header>@include('partials.header')</header>
    <main>@yield('content')</main>
    <footer>@include('partials.footer')</footer>
</body>
</html>
Final Tip
If you’re stuck, check the theme’s documentation or look for a readme.txt file. Also, ensure your PHP-Nuke version matches the theme’s requirements. For modern projects, consider migrating to a supported CMS.
PHP-Nuke is a web-based automated news publishing and content management system based on PHP and MySQL originally written by Francisco Burzi. The system is controlled using a web-based user interface. PHP-Nuke was originally a fork of the Thatware news portal system by David Norman.
