DNS Troubleshooting Guide for Xisto Hosting: Fixing Suspension and Accessibility Issues
If your Xisto-hosted site gets suspended due to DNS issues, you’re not alone. Many new users run into propagation delays or misconfigured records that make their site appear down—or worse, trigger automatic suspension. Let’s break down how to diagnose and fix these problems step by step.
Common DNS Problems That Cause Suspension
  • Incorrect nameserver settings: Your domain must point to Xisto’s nameservers. Double-check in your domain registrar’s control panel.
  • Propagation delays: DNS changes can take up to 48 hours. Your site may appear offline only to you because your ISP caches old records.
  • Missing or misconfigured A/AAAA records: The domain’s A record should point to Xisto’s IP address (or use a CNAME if provided).
  • Reverse DNS issues: Rare but can affect email deliverability.
How to Check If Your Site Is Really Down
Use these tools to see if the problem is global:
  • Pingdom Tools – Check uptime from multiple locations.
  • What’s My DNS – Shows propagation status worldwide.
  • Browser’s Incognito Mode – Bypasses local cache.
Step-by-Step Fix
  1. Log into your Xisto cPanel and verify that your domain is listed under “Domains” or “Addon Domains”. If not, add it.
  2. Confirm nameservers at your registrar: they should be ns1.xisto.com and ns2.xisto.com (or whatever Xisto currently provides).
  3. Wait for propagation – after changes, give it up to 24 hours before panicking.
  4. Check the suspension reason – Xisto usually sends an email. Common triggers: exceeding resource limits or having an incomplete setup.
Today, DNS management is more user-friendly than ever. Many registrars offer one-click integration with hosting providers. For Xisto users:
  • Use DNSSEC if Xisto supports it – adds a layer of security against spoofing.
  • Enable Cloudflare’s DNS as a proxy to speed up delivery and hide your server IP (if allowed by Xisto’s terms).
  • Monitor your DNS with tools like UptimeRobot or Better Uptime to get alerts on propagation failures.
  • Keep your domain’s TTL low (300 seconds) during initial setup so changes propagate faster.
Remember: Most DNS headaches are temporary. Double-check entries, wait, and use online checkers to confirm. If your site stays suspended after 48 hours, open a ticket on Xisto’s forum with your domain and the exact error message.
Pro Tip: Always test changes from a device not on your home network (like a mobile hotspot) to see if your ISP is caching old DNS.
The Domain Name System (DNS) is a hierarchical and distributed name service that provides a naming system for computers, services, and other resources on the Internet or other Internet Protocol (IP) networks. It associates various information with domain names assigned to each of the associated entities. Most prominently, it translates readily memorized domain names to the numerical IP addresses needed for locating and identifying computer services and devices with the underlying network protocols. The Domain Name System has been an essential component of the functionality of the Internet since 1985.
