abdo1405241556
Help Me Load Balance
No sure that this is possible.Are both your adsl lines from the same supplier?If yes, you can ask permission for creating a link aggregate, and if your PC is a Linux one, you can create a link aggregate with your two nic's.
the two line aren't same isp
Yes, You can use different ISPs. But for that you need two modems for each ISP and one load balancing router.
For the Example of this type of setup you can visit : elperfectouter
OR
You can use LANCOM 1721+ VPN like device which has inbuilt adsl modem.
Edited by agyat
Please sign in to comment
You will be able to leave a comment after signing in
