Rs-Server
How To Change Your Ip Address. In Less Than one Minute, Change Your Ip
Firefox is only allowing the same sites as my Internet Explorer. This might be a dumb question but is there anyway I can restore my old firewall settings, system restore wouldn't work?
before re-trying the google test, re-do the ping trick with "ping https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl;Then, in order to temporarily stop the Microsoft firewall, click "start", then "settings", "control pannel", or something like that, and you will find the firewall menu, and temporarily choose "stop the windows firewall".
If then everything happens to work without the firewall, this means that the firewall is responsible of the thing, and now we know where the problem is coming form.
If the internet does not work correcly with disabling the firewall, then, the problem is coming from somewhere else, and we will have to have a more careful look at the gateway address.
Pinging google didn't work and I can't find my firewall anywhere. :)
Where else could it be?
OK, if now we start seeing more clearly where it comes from.
If you can ping http://forums.xisto.com/ and you cannot ping https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl,'>https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl,
the problem is not inside your firewall.
The problem is in your gateway or in your dns.
The dns is in charge of translating the https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl name to google's ip address.
And the gateway is in charge of routing the IP packets from google to your PC.
So, one of these changed, either in your PC when you touched your own IP, or at your Internet provider main site, althoug I thing the latter is less probable.
when you ping https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl,'>https://www.google.de/?gfe_rd=cr&ei=BwkjVKfAD8uH8QfckIGgCQ&gws_rd=ssl, do you see an IP address appearing ?
Yordan
Yeah, I think so.
Is it okay to post it here?
Please ave a look again.
When you do the ping test, if you see an IP address for Xisto.com and for google.com and google does not appear at the browser, then this means that your proxy address is not set correctly.
Stuck after step 19
Everything goes smoothly until step 19. After all the steps are done the MSDOS prompt screen is still there staring at me. How do I get out of it.? It will not "X" out and I eventually end up having to unplug my computer to get rid of it.
Help!
-reply by Dion
be in US or euorpe?
Hi I wanna play an online gae that requires me to be in either us or euoro as they block all ips out of these regions any idea how to change my ip /proxy to pass this ?
Btw the game isnt browse based it needs aclicent to download
Thx
-reply by mada
I am using a Realtek network card , and I did the following:Network Connections --> Right click in your connection --> Properties --> Configure your Ethernet Card--> Advanced tab--> Network Address --> enter new 12 digit valueWhether or not you can do this probably depends on your network card. Also I'm not sure whether I have changed the internal or external IP this way (any ideas?)-reply by proton
Thanks!!
Omg it worked first it cut my internet off and I was worried my mom would kill me :D But then I thought I better do the rest.. And it worked now I got a new one ^_^ thanks allot mate you explained it really good hi5!
-feedback by Sarah
