Having trouble accessing your Xisto-hosted site? This is a common issue that can stem from several causes. Let’s walk through the troubleshooting steps systematically.
Step 1: Check Xisto Server Status
First, verify whether Xisto’s servers are online. Check the official Xisto status page or community announcements. If there’s a known outage, your site won’t load until it’s resolved.
Step 2: DNS Propagation
If you’ve recently pointed a custom domain to Xisto, DNS changes can take up to 48 hours to propagate globally. Use a tool like whatsmydns.net to check if your domain’s A record points to Xisto’s IP address (usually 216.245.222.14 or similar). If it’s still showing old records, wait or flush your local DNS.
Step 3: cPanel Configuration
Log into your Xisto cPanel account. Ensure that your domain is properly added under “Addon Domains” or “Parked Domains”. Check that the document root is set correctly and that the website files are present. Also, verify that your index file (e.g., index.html, index.php) exists in the public_html folder.
Step 4: Firewall and Browser Cache
Sometimes your local firewall or antivirus can block the site. Try accessing your site from a different network (e.g., mobile hotspot) or disable your firewall temporarily. Also clear your browser cache and DNS cache (ipconfig /flushdns on Windows).
Step 5: Contact Support
If none of the above works, post in the Xisto support forum with details: your domain name, what error you see (e.g., “This site can’t be reached”, blank page, etc.), and whether other Xisto sites load. A staff member can check server-side logs.
Remember, Xisto’s free hosting relies on community participation. If you’re inactive, your account may be suspended. Make sure you’re logging into the forums periodically to keep your account active.
Let me know if you need further help!
