Back in the day, multi-boot meant burning multiple OS installers onto a single CD using tools like EasyBoot or Nero. With optical drives becoming rare, the focus has shifted to USB drives, but the idea is the same: carry a handful of live environments or installers on one stick.
What’s the State of Multi-Boot USB in 2026?
I’ve been trying to find a reliable way to create a multi-boot USB that can handle Linux distros (Ubuntu, Fedora, Arch), recovery tools (SystemRescue, GParted), and maybe even Windows installer. So far, I’ve found:
- Ventoy: This is the big one. Install it once, then just drag-and-drop ISO files onto the USB. It boots them directly without reformatting. Supports legacy and UEFI, and even persistent storage for some distros.
- Rufus: More for single-boot, but can do multiboot via its “bootable USB” mode with multiple ISOs? Actually, Rufus is mainly for writing one ISO at a time. But you can manually partition and add ISOs, but it’s not as slick as Ventoy.
- UNetbootin: Old but gold for single installs. Still works for some, but not ideal for multiboot.
- YUMI: Fork of MultibootUSB, but it installs a custom bootloader and then you add ISOs. Works, but sometimes breaks with newer ISOs.
I’m leaning toward Ventoy for its simplicity. Anyone here using it? Have you run into any issues with SecureBoot or specific distros? Also, does anyone still bother with CDs for this? Would be curious to hear your setups.
Personally, I keep a Ventoy stick with about 10 ISOs, and it’s a lifesaver for troubleshooting machines. I’m thinking of writing a small guide for the forum on how to set it up with Xisto’s free hosting to share the config files or something.
What’s your go-to tool and why?
Topic Summary: Comparison of modern multi-boot USB tools like Ventoy, Rufus, UNetbootin. Ventoy’s drag-and-drop approach wins for flexibility. Tips on SecureBoot, persistence, and future trends in bootable media.
title: Multi-Boot USB Creation Process
Start([Start]) --> ChooseTool{Choose Tool}
ChooseTool -->|Ventoy| V1[Download Ventoy]
V1 --> V2[Install Ventoy to USB]
V2 --> V3[Copy ISO files to USB]
ChooseTool -->|Rufus| R1[Download Rufus]
R1 --> R2[Select USB drive]
R2 --> R3[Choose partition scheme MBR or GPT]
R3 --> R4[Select ISO file]
R4 --> R5[Write to USB]
ChooseTool -->|YUMI| Y1[Download YUMI]
Y1 --> Y2[Select USB drive]
Y2 --> Y3[Select ISOs to add]
Y3 --> Y4[Install bootloader and copy files]
V3 --> Test[Test boot on target system]
R5 --> Test
Y4 --> Test
Test --> End([End])
Featured GitHub Resource:
YouTube Video:
Official Documentation & Reference Links:
I’ve been using Ventoy for the past two years and it’s hands-down the best solution. The fact that you don’t have to rebuild the USB every time you add an ISO is a massive time-saver. Plus it works with UEFI SecureBoot if you enroll the MOK key.
Why Ventoy Wins
- Zero formatting: Just copy ISOs into a folder. Ventoy’s bootloader scans and presents them in a menu.
- Compatibility: Supports Windows, Linux, even BSD and some macOS recovery ISOs (though that’s trickier).
- Persistent storage: For distros like Ubuntu, you can create an overlay file to save changes. I keep a 32GB USB with persistence for Kali and Ubuntu, plus a dozen other ISOs.
- Active development: The dev pushes updates regularly, and the community is responsive.
Drawbacks to consider
- SecureBoot: While it works, you may need to configure your BIOS to trust Ventoy. Some enterprise machines (Dell, Lenovo) may require extra steps.
- Very old hardware: Some legacy BIOS implementations might choke on Ventoy’s menu. In that case, I fall back to Rufus with a single ISO.
- ExFAT issues: If your USB is formatted exFAT, Ventoy can sometimes have trouble with large files. I stick to NTFS or ext4 for Linux-only sticks.
I actually ditched my CD collection years ago. For the rare occasion I need a bootable CD (like for a vintage Mac), I use an external USB DVD drive with ISOs burned via cdrecord. But honestly, that’s maybe once a year.
If you’re setting up a multi-boot stick, I’d recommend:
- Use a USB 3.0+ drive (64GB or more) from a reputable brand.
- Format it as NTFS (for Windows ISO compatibility) or ext4 (if only Linux).
- Install Ventoy via their provided script (on Linux:
sudo bash Ventoy2Disk.sh -i /dev/sdX).
- Then just copy ISOs. Done.
For anyone on Xisto’s free hosting, you could host a small script that automates the download of common ISOs and sets up the USB. That would be a cool project.
If you’re set on using CDs, you can still use older tools like EasyBoot or Nero, but good luck finding a working optical drive. The future is USB.
This thread really highlights how far we’ve come from the EasyBoot and Nero days. The shift to USB has been transformative, and tools like Ventoy have redefined what’s possible. Unlike the traditional approach of writing an ISO directly to a USB (which essentially ‘burns’ it like a CD), Ventoy uses a clever bootloader that presents a menu of ISOs stored on the drive. This means you can swap ISOs without reformatting, a massive convenience for anyone managing multiple environments.
The diagram captures the decision flow between Ventoy, Rufus, and UNetbootin. But it underrepresents a key nuance: Ventoy is not just another tool in the same category. It’s a paradigm shift. Rufus and UNetbootin are still ‘write once’ tools even if they allow multiple ISOs through complex partitioning. Ventoy, by contrast, treats the USB like a simple file server. This matters for IT professionals who constantly test new distros or tools. Ventoy also supports persistent storage, which allows you to save changes to a live session—invaluable for penetration testing or recovery tasks.
One emerging trend is the integration of cloud-based booting. Services like netboot.xyz allow network booting of thousands of ISOs without any USB at all. But for offline scenarios or when you need a physical fallback, the USB remains king. Modern multi-boot USBs also need to handle SecureBoot. Ventoy addresses this by allowing MOK enrollment, but it’s not always seamless. Some enterprise BIOS implementations still cause hiccups, which is why having a Rufus-only stick with a single ISO can be a reliable backup.
Another consideration is Windows 11’s strict TPM and SecureBoot requirements. Multi-boot USBs must handle Windows installers that expect UEFI with SecureBoot enabled. Ventoy can boot Windows ISOs directly, but for Windows-to-Go scenarios, tools like WinToUSB or Rufus with Windows image options are more appropriate.
Looking forward, we’ll likely see USB drives with built-in SD/microSD slots for even more flexibility, and tools that can leverage Wi-Fi direct for peer-to-peer ISO transfers. But for now, Ventoy represents the pinnacle of practical multi-boot USB creation. If you haven’t tried it, give it a spin—you’ll never go back to burning ISOs one at a time.
